Does anyone have a list of frame numbers?
I am trying to work out what year mine is, as the date stamp is not clear.
Thanks.
PX50 frame numbers
Re: PX50 frame numbers
hele
AB05 IS 40 PH
AB06 IS 25 PH
do you have a picture
px is between 1980 -90
not mich collors org
red
, white , blue , black , the R's with gold grimeca wheels the black with yellow wheels , the red whit white wheels
best regards
AB05 IS 40 PH
AB06 IS 25 PH
red
best regards
flyer one 1984 models
flyer two 1987 models
flyer 3 1988 models
flyer 4 1989 models
they look the same
just the firts models have no elec starter and are elec ignition 6 v
as you use attatchments left below you kan go in your pc maps and set a photo
thank you
best regards
flyer 3 1988 models
flyer 4 1989 models
they look the same
thank you
best regards
Hi,
Thanks for the brochures.
I'll try and attach a picture. Mine is a 12V electric start.
Thanks,
Martin.
Thanks,
Martin.
Only picture I can find.
Hopefully that worked this time!
hello its a, elec one black seat
so 1980 and 81 there where no elec ones
from 1982 wel
your pvgnr says 80/6002
1980 where tehb first so they kept that
ab 06 is a 25 p h
i would gamble it on 1984-85
but for sure he is between 1982 86
from 1987 they had grey seats
good luck
best regards
from 1982 wel
ab 06 is a 25 p h
good luck
best regards
