rear brake plate grimeca vs rigida/spoked + rim widths
prawny12009
Post by prawny12009 »
Are the rear brake plates the same between grimeca wheels and the rigida composite wheels? I have found out the fronts are different but I intend to disc convert the front anyway possibly with the puch front mag that takes a bolt in hub.
I know the composite wheels are 1.5x17 what widths are the grimeca mags?
I'm looking at a few camino's in the uk but they all seem to have either 6 spoke rigida composite mags (not keen on them look too fussy) or wire wheels (bend/buckle easily and snap spokes), i would like to figure out what i need to go 5 star and the differences between parts before ordering.
prawny12009
Re: rear brake plate grimeca vs rigida/spoked + rim widths
I've found pictures of Both types of rear brake plates so to answer my own question, yes they are different.
I would still like to know the rim widths of the grimeca wheels if someone could check the marking on theirs.
hello
the rigida brake plates are the same as the spokes wheels
80 mm max brakeschoes
foto 3 & 4 rigida of spokes wheel brake plates
the grimeca brake plates are diffirent
90 mm max brake schoes
foto 1 & 2 grimeca brake plates )
any questions just ask
best regards
marc
and a tip
for the rigida and spokes wheels the brakeschoes also models from puch are the same
and honda amigo-novio also
brakeplate amigo -novio is the same brand leleu as camino spokes wheel and rigida
good luck
prawny12009
any idea on stock rim widths for each different wheel, spoked, 5 star and six star? (i know 6 star is 1.5)
camino wheels grimeca and rigida-radaelli and spokes are the same on 17inch
https://www.jmpbparts.com/universal/bod ... elgen.html
but the grimeca wheel is full of alu ,as it's hard broken you can trow it away
rigida-radaelli , its is to see on the wheel atselve
goodluck
Happypancake
Post by Happypancake »
I'm looking for a rear brake plate for a 90mm 5 spoke. Shipped to US.
Happypancake
Anyone know where I can get a 90mm brake plate. Im located in the US
i got a set
for grimeca wheels
the front one i got a few
let me know
best regards
Happypancake
Sent a pm.
ok :thumbsup:
