Cylinder
- Camino is the best
Between brackets:clio-tuning wrote:You can buy a Suzuki Katana vario (en hem aanpassen voor camino)...Anden wrote:I just have the problem that the camino is only sold with 3 roller vario in denmark, so i can't find it here
Will anyone translate this plz?
And adapt him to your Camino .
In het bezit van:
Opel Astra F 1.8 16V 1997
Opel Kadett C 1.2 N 1978
Opel Kadett E 1.6 SV Cabrio 1991 (for sale)
Okay, i'll look on it soon, i've just solved the problem about the exhaust today. I found a biturbo exhaust for puch maxi in a corner in my garage, and i made it fit, and now it is just pulling on the backwheel, and the acceleration comes much earlier, and it sounds very good. And even the top speed got 10km/ per hour faster.
You can see it here: http://www.scootergalleri.dk/html/gal_v ... ipc=403854
The dent is there from the factory, it is not something made by an accident, you can see it here, even if it is a bit unclear
http://www.protunahandels.de/product.as ... n=19068149
It made my acceleration much better than with the gianelli, and my topspeed is also a little better, i will say that it is quite good, and so it is very cheap( in Denmark it cost's about 35euro), it doesn't fit camino, but if you take the front pipe from an original camino exhaust or makes a pipe yourself, it is pretty easy to get to fit. The best thing about it is the sound, it sounds even better than a proma circuit, it has a very deep sound, and so it looks quite good :-DÂÂ
