Hello,
i bought Honda PX-R and it drives only 25 km/h but the main point is that i can't really find any tuning variators. My question is: Is there some alternative which variator to buy? For example tuning Variator for Honda Wallaroo, or is the front pulley same as Camino? I'm new in these things. Thank you for advices
Honda PX-R Variator
Re: Honda PX-R Variator
hello
you can use the bowen ones for from the wallaroo
a fast arrow star of a S 72 star
you have just to drill the center hole of the str a little bigger , so it fits on the px cranck , an it fits perfect in the px wheight scale
good luck
as you cant find none , i stil gota few for wallaroo
check also your belt it has to be between 14 and 15 mm , 12 of 13 mm is not good anymore
the 25 p h px
maybe make the exhaulst port of your cilinder also a little bigger
of put a 65 cc cilinder on it
it wil pull very hard and to see with exhaulst
px are not many special anymore but a good 45 a 50 p hours is possible with a very good pull
best regards
good luck
the 25 p h px
best regards
