Standard carburator
Standard carburator
How big can i drill my standard 12mm mikuni carburator, and can i use my standard cylinderhead on a 70cc athena cylinder?
- den_phille
- FlamingProma
you can make the original carburator bigger but better not with a standard bore, better try an oval shape whth some tuning tools, so you won't damage the spcial channels on the sides that you don't see... till you damaged them.den_phille wrote:otherwise your piston will hit the bougie
a standard cilinder head is perfect possible but you have a chance that the piston hits it, you can feel it it you turn the flyweel around very slowly, you can place an extra head sealing but also a foot sealing, in my opinion it's better to place a foot sealing, so al the ports opens more and the flow is better
geheiligd is Uw smaak,
Uw walm kome,
Uw alcohol beïnvloede,
en vergeef ons onze zatheid,
maar verlos ons van de kater
Amen
Uw walm kome,
Amen
- FlamingProma
with an original one should be good enough if you adjust jour main jet, don't forget changing exhaust, variator rolls, clutch springs,...Anden wrote:Okay thanks for the help, but i think that i later on will buy a 20mm dell'orto spaco carburator, but can you make the standard intake big enough? it's just because you can't buy a bigger one here in Denmark
Uw walm kome,
Amen
Uw walm kome,
Amen
- FlamingProma
you need lighter variator rolls and stronger springs this will improve your acceleration very much, you can alwais buy parts by http://www.mopshop.de, it's an excellent service
Uw walm kome,
Amen
Uw walm kome,
Amen
- FlamingProma
Vario 6 bill have 16*13 rolls
- FlamingProma
http://www.mopshop.de/shop/index.php?ca ... b9154d7082
http://www.mopshop.de/shop/product_info ... b9154d7082
can't find the springs sorry
its 14*16
its 14*16
Uw walm kome,
Amen
Uw walm kome,
Amen
