How do you take out the carburettor?
fender
Post by fender »
I think my carb is blocked inside (engine does not idle).
Needs then a good clean. How do you go about taking it out as it is under the frame itself?
Any information please?
Thanks.
InSane
Re: How do you take out the carburettor?
Post by InSane »
Loossen the one bolt thats holding you're engine to you're frame. You're engine wil come down now so put something under it. Nou you have some more space to get to the carb :wink:
Good luck
Greetz Dirk
Ganja
Post by Ganja »
In between your engine and your carb there is a little metal thing (don't know the English noun) and you've got to loosen those 4 bolts . When you completed that you can unplug your carb from the metal thing by the 2 little nuts. Now you have only your carb, you loosen the 2bolts that hold the gasoline chamber. Make sure that you don't wreck the little rubber that you see at the edge of the chamber.
I hope you can understand what I've written.
greetz
Burn rubber, not your soul
Proud to ride the best 2stroke moped ever made
noogie
Post by noogie »
go onto http://www.mopedarmy.com
there is a lot about removing the carb from a camino in the forum sections of that website, they call a camino a honda pa50 though, or sometimes a honda hobbit
