Different between 3-and 6-bil vario?
Waldi1
Post by Waldi1 »
Ich habe gelesen, dass es eine 3 und 6 bil-vario. Können Sie sagen mir, was ist anders?
War die ursprüngliche 6-bil oder ist es ein Tuning-Teil.
Ich denke, 3 in das Gesäß sind nur 3 vario rollen ein Gesäß sind in den letzten 6 Rolle 6. Aber hat es noch die vario funktion anders?
Kann ich 3 in das Gesäß auch vario 16 * 13mm Rollen? Wicht, was die Standard-Rolle nicht haben?
Vielen Dank Walti
klainstain
Re: Different between 3-and 6-bil vario?
Post by klainstain »
Nein, keine 16 * 13 aber 14 * 14 mm
→ Athena 70cc
→ Dell'orto 21mm
→ Ninja/Sito uitlaat
The left one is the 6-bill, the right one the 3-bill
if you compare them ( original , not tuned), the 3-bill has a slightly better acceleration.
And the 6-bill has a slightly higher top speed.
The six-bill is also easier to adjust the weighst.
Waldi1
Post by Waldi1 »
I have the 3-bil vario, but where can I get different wight?
I was searching but i can only find 16x13mm roll.
www.mopshop.de
jve
Post by jve »
espower.nl sells 14x14 weights .
14x14 are very rare to find cause there aren't any scooters that use these
and i dont think 3-bills have 14*14 weights :s
klainstain
Oh yes it's right !
The size is different from 14*14 :oops:
→ Athena 70cc
→ Dell'orto 21mm
you can only buy them originally from hoda i think
And if you need lighter weights in your 3-bill, you can bore the hole in it a bit bigger.
If you need heavier weight, solder them a bit.
I hope solder is a good word, you do it with this:
Waldi1
Post by Waldi1 »
Ok thanks!
I will try it.
Can i get a 6bil vario, as tuning part? In a shop? because i think i can adjust the 6 bil with the different weights better.
you can buy an old one from other people maybe? :wink:
duf
-= Elite Member =-
-= Elite Member =-
Post by duf »
jasper wauters wrote:you can only buy them originally from hoda i think
doing this is absolute wacko!
you can never! get equals weights that way,
not with drilling, and especially nog with soldering it.
It will turn out of the center wich will cost you your crankshaft and maybe more...
~ Sprint Camino ~
Malossi 70cc MHR cilinder ~ Malossi MHR Krukas ~ Malossi Rotor ~ Yasuni C21
Malossi MHR vario ~ MHR overrange ~ Stage6 koppeling ~ Keihin 28mm semi valstroom
V-force
jve
Post by jve »
indeed duf
the weight realy needs to be distributed equially
cause otherwise it wil kinda be like a soccer ball that does not have enough air in it witch can cause serious damage to your vario
ow, sorru guys, just trying to help
but is drilling also that bad?
jve
Post by jve »
when you drill a hole its not 100% round
its oval ? ( don't know if this is the correct word)
Mr.Gti
Post by Mr.Gti »
this is generel discussion only in english why do you write in german ? i can also german but is it on better in english
