Hello,
I have bought polini clutch springs from mopshop but they didn't fit! I have found some on www.treatland.tv but I don't know the right size. there stand the diameter and the length. but I don't know is it the spring length or from one hook to the other hook.
Please can someone tell me which one I should select.
Thanks!
Want to buy stronger clutch-springs but where?
Re: Want to buy stronger clutch-springs but where?
You can buy them on http://www.espower.nl.
These are the three different springs that fit on a Camino clutch:
15%
25%
40%
15%
25%
40%
Thanks!
I have looked on the shop... but I didn't find springs for the clutch. Only in the general spring ordner but there I also don't know which I should take.
Please can you sned me the correct Link.
He already gave you the links:
But if I may give you any advise: Buy a set of 15% and 25%. The clutch of a camino isn't very strong and you're already taking it far with the 25%. Chances of warping the clutch arms is high. Some clutches can handle the 40% springs, most don't. If you can find a replacement fast then its another thing of course..
sorry! I didn't see that it is a link!
Perfect I will order 15% and 25%.
