more power
more power
Hi camino fans, i have a 1988 mint camino DX ,133 miles on the clock and would like to get a little more power out of it, whats the best way to achieve this without any major modifications.
Re: more power
hello
do you have a photo ?
is it a engine with variomatic and a 4% moped ? of a 2 %
of motor with flat belt
more ower use a 65 cc cilinder
but carefull
you have to see with kind off rampvarioplate you have
of the motor with flat belt
you have to see that you can hold the rpm's so low as possible
for overheated engines and cilders to envoi
best brands DR and malossi and polini
dr is the most at a price that is not over the edge
but can you show a photo of the motor
as it is in the uka i suppose as it is a vario they go allready a good speed original
the exhauls plays also a part
not noisy and best pull sito
but hard to get new
than the more noisy ones proma by technigas , this one gives also a little bit more speed
any questions just ask
good luck
best regerds
marc
but carefull
but hard to get new
good luck
best regerds
marc
