Hi guys
There’s some good reading on this Camino forum, thanks for having me here.
I’m the lucky owner of this Camino, it belonged to my late father, it last run in 1993.
I’ve replaced the carburettor, given it a clean up, new fuel and it started first time.
The problem I have is the electrical side.
None of the electric work, there’s no battery on this model. I’m totally useless at electrics, not bad with the spanner’s lol. So if I ask anything that sounds stupid about electrics please forgive me
Also I want to restore it to show room condition, I would like to know can you still buy the Camino decals on the fuel tank.
New Camino owner, from Doncaster U.K.
Re: New Camino owner, from Doncaster U.K.
Trying to put pictures of my Camino on here, I’m using an iPad,
Can Anyone explain how it’s done
hello
At the left unterside of the page are options
You click on bijlage,
Than on bestanden toevoegen
So you can get a photo out of your pc map
i did a bleu one
i did a bleu one
but not use quick response
use the reaction page
If you got troubles with the electric at your moped
as you can set a photo , so i can see wich model
there are models with battery , and with no battery
i can set the UK electric scedual if you like
decals are available in belgium , copy's of the most models
i will read it
thank you
best regards
i will read it
thank you
best regards
the scedual for the uk models
best regards
ps
do you like decals like on your moped ?
you can find them here
www.bromfietsenkurt.be
best regards
ps
