Hello,
I just found this forum while I was searching for some alternatives to the standart PX 25 vario.
Im from germany, got one PX-R with the Sito exhaust and a tuning Vario.
At the moment I'm restoring a 1985 PX.
So I'm still searching for the alternative for the PX vario.
Ist Honda part nummer for the Wallaroo plate 22131GR1750 correct?
Do I still need the varios backplate, which ist crewed to the housing?
Regards,
Daniel
Hello from Germany
Re: Hello from Germany
hello
the wallaroo plate kan you perfect use with a little work at te plate
make the hole , like the hole as the px plate and it fits
the S72 plate , fast arrow plate fit all in the org wheigt scale from px
the backplate not use it anymore
it holds till the org kl B plate
the wallaroo plate oder s 72 plate are more bowen
yes the honda nr is correct
as i said make the hole a little bigger that is fits on the px kurberwelle
ich wunsche du fiel gluck
as du frage hast , bitte , , antwort 1 oder 2 tagen
mfg aus belgien
mfg aus belgien
Hi,
perfect. Thanks a lot for your help.
For sure I will come back to you with problems in future
