jerking drive
Weeman
jerking drive
Post by Weeman »
Not sure if forum is still active if so can anyone help?
My machine jerks when driving belt seems OK.
Ed
Re: jerking drive
Not very active anymore.
"Jerking" if I understand correctly, you mean like stuttering.
It's usually the carburetor that needs cleaning.
Also after you have cleaned it, make sure you use a filter on your fuel intake from the tank.
It could be that the tank has rust on the inside.
Weeman
Re: jerking drive
Post by Weeman »
No the machine is jerking so badly the whole bike shudders back transmission makes strange noises
Ease the throttle and it calms open up and it starts again.
Removed and cleaned carb, fitted new coil and CDI checked vario .problem still there engine starts ticks over and revs normally.
Help?
Ed
Re: jerking drive
If the whole bike shudders, maybe it's the bearings inside the engine?
