Evening everyone new to the forum thanks for letting me join, I’ve recently acquired a 1979 Camino dx50 in original condition which has not been on the road for 10 years but does run but is a bit smokey, so I’ve striped it down cleaned every part, done new piston and rings but yet to fire the old girl up, the only thing I’m trying to source is a headlight as this one is cracked and discoloured, can anyone point me in the right direction.
P.s how do I post an image on here
Headlight for dx50 (1979)
Re: Headlight for dx50 (1979)
welkom mattb
as the moped has a longtime beeing out of use
best is carburator clean
check the breakerpoint
check the sparkplug
for pictures go to (volledige bewerker& voorbeeld) than you can use attachments for pictures
good luck
any question be free to ask
thank you for yoining us
best regards
check the sparkplug
good luck
best regards
I’ve had the carb striped down and ultrasonic tank cleaned and reinstalled it today kicked her over and it started first time with no smoke so I’m pursuing doing the pistol and rings sorted it. I’ve attached a picture and can’t wait to get her Mot’d and on the road.
ha super
its a uk one
i see it at the rear light
good luck
have a lot off fun with it
any questions just ask
best regards
its a uk one
good luck
best regards
Yes 1979 UK version
I don't think that kind of headlight was used here in Belgium.
that kind was wel used
but not in creme color in belgium on camino that's correct
well in black , brand soubitez (camino S young ) called , see on flyer
see photo
but they are in belgium used on honda amigo -novio in that creme white
and the creme ones for camino's , the most in germany france and the uk , and some other countries
the rear light off your camino org only in uk on camino
with the huge nr plate
see photo
