I drive a camino whit a 21 carb, Athena 70cc cylinder, Proma exhost, and i was just wondering what jet size ( i think its called jet) you guys uses on this, i got a 85 now and i have to build up the gass verry slowly or it just dies! But if the back wheel is free, like abov the air so its no weight on it i can give full gass and no problems
And i was wondering where i could buy a new start clutch and normal clutch for it
With a kitted honda I have heard a jet range in the 90's would be sufficient.
What head are you running with that Athena kit?
as for the lack of power - Im actually having that problem too, I think its either a leak or too small of a jet.
My plug chops are coming out too clean, Im running lean and I don't think it is an air leak.
You want your spark-plugs to come out looking chocolate color on a WOT run. But just check it first in general to see if it is clean or oily
I bet you can't get it to idle too can you? I'm not sure if you need a different idle jet on a phbg /del carb
You meet the nicest people on a Honda '78 Hobbit PA50I
Caminonorway wrote:...and i have to build up the gass verry slowly or it just dies! But if the back wheel is free, like abov the air so its no weight on it i can give full gass and no problems
I've had a simillar problem. My camino drived very poorly. (about 10m/h to slow // (15km/h to slow)
When he was on his stand, I could gas it and there where no problems. As soon as I sat on it and drived, the same problem.
The reason was that there was an airleak between the aircompartment and the rubber air-inlet.
It should be glued with silicone.
I've learned a trick to check it from someone here on camino tuning.
You have to close one hole of the rubber with a tissue or something. (the rubber with 3 holes)
(just to test if the problem is there, you must remove the tissue later!)
Than drive a little and see if the problem remains or not. If it remains, don't do anything with the inlet.
If it helps, than there is an airleak between the rubber and the aircompartment.
