hello from Portugal
alfro04
Re: hello from Portugal
Post by alfro04 »
Sorry but this like a new toy when you kid...but this one does not have a hooter, was thinking of put one in the front where the head light is screwed on, i just need the a push button on the stering wired to the hooter...is there an extra one that i can buy ? :-D
there are some Camino's with a horn. Custom's and some Camino DX.
But that horn is wired to a battery.
The battery is for the horn and traffic indicator. If the motor isn't turned on, the lights, indicators and horn doen't work.
If the motor is running, the battery charches automaticly.
You can hang something like this.
Or this is original for camino.
alfro04
Post by alfro04 »
good idea, i got one of the rubber horns... :-D
alfro04
Post by alfro04 »
standreww wrote:Turn it al the way in. Than 360 + 90 degree out.
That's your basic configuration.
Drive the camino warm. Always configurate your carburetor with a warm engine.
From there you must listen to the rpm.
The air screw must be so that the engine makes the most rotations per minute.
If the wheel turns, adjust the leftmost screw, that controls the gascable.
Now it's time to take it for a spin. Make sure your brakes work!
From there, you should drive at full speed. Then immediately shut down the engine.
Than check your spark plug.
The color should be coffee with milk brown.
If i'ts black, it means the bike get's too little air >> turn the air screw looser.
If it's white or gray the bike get's too much air >> turn the airscrew tighter.
(about a quarter each time)
than again drive a bit full speed, and check spark plug again.
Be careful with the sparkplug, don't turn it to tight.
Hi
i canot get it to idle properly,
1-the screw under the carb deposit should be total screwed in or about a couple of turns out??
2-About the air filter, this has got one, i put some kitchen extractor filter material to avoid the sand power to get in..
thanks
1. That screw must be totaly screwed in. It has to be tight.
It's purpose of the bottom screw is to drain the carburettor if you clean the carb with compressed air trough
the silver screw beneath the airmixture screw.
2. Your camino will only run properly with the right airfilter. Partnumber of the original is "honda 17205-148-610"
Maybe you can find it on the internet with the number.
The airfilter should be slightly drained in oil. Best is airfilteroil. This is done so the dust sticks in the filter.
alfro04
Post by alfro04 »
standreww wrote:1. That screw must be totaly screwed in. It has to be tight.
Ok thanks, i will keep on posting.
alfro04
Post by alfro04 »
Hi again.
I have stripped the carb again, i miss cleaning the tube inside the jet, but its so tight i just soak with penetrating oil...
Original the float was filled with petrol so i have cleaned it but keeps on filling in, so i need a new one.
can i buy it in Europe? there are 2 in Usa ebay, but if custmos grab it here it will cost me double to clear, my best bet is europe, surely i can, the bike was made in Beigium. :-D
I've seen it once, with my girlfriends camino. The float was full of petrol.
The only thing you can do is get a second hand or a new one.
(New is hard to find. I think it's impossible.)
Best chances for a second hand. I can send you one if you like.
The tube. Best way to get it out.
Take one string of a brakewire.
Push it trough from bottom to above.
Let it make a curve so you can pull it half way trough.
Now, make a triple knought. And pull it out bottomways.
Now the tube should come out.
Clean with compressed air. It's purpose is to drive at half speed.
If the holes are clean, it's better.
alfro04
Post by alfro04 »
I got the tube out, strip the butterflies off put a screw drive throught the bore and push it down, i marked the position, i donot know if is important..
About the float i manage to find the tiny hole super glue it i will see if it holds.
They do sale new ones on the states ebay...the problem is custmos here...if bought in Europe you donot have that problem.. :-D
Easier way to take the tube out: take a bycicle spoke
Bend the final cm of the spoke 90 degrees
Insert it from the choke side inside the carb, into the tube hole and push...
By the way your Camino was made in the '80s: see the type plate on top in the front of the frame: BAUJAHR 198.
alfro04
Post by alfro04 »
yes good ideia, i got some pictures of the bike here...i think you right about 80s :-D
https://plus.google.com/photos/10007486 ... banner=pwa" onclick="window.open(this.href);return false;
alfro04
Post by alfro04 »
alfro04 wrote:HI again
I manage to fix the float, i got engine going, but i canot adjust the air screw...with choke on seems ok but choke off, it keeps on acelarating canot control it down...how do set this up??
to back this up here is a video..." onclick="window.open(this.href);return false;
thanks
HI
i have done everything still cannot set the engine to iddle it stops as soon as i move chock lever back.. there is no adjustment at all, like on the movie i made.." onclick="window.open(this.href);return false;
i though maybe the timing is out...i do i set it??
thanks
Post by GoBieN »
Not sure what you are showing in the movie.
- Does the wheel keep turning in idle?
- Or does the motor stall when you put choke off?
alfro04
Post by alfro04 »
hi
I got new spark plug and new carb float(the old one was badly damaged) it does not keep the idling , you got keep on acelarating with choke off. :)
thanks
Post by GoBieN »
So it stalls if you release the gas. Is the idle screw turned in all the way?
