Honda Camino 65cc kit
Re: Honda Camino 65cc kit
i think here in Belgium is no store, where we can buy another spring.
stiffer is better, because your acceleration will increase, pulley stays longer closed and
your camino will run much better
Oki thanks for your information. I have ordered a stiffer spring. I just need to
cross my fingers that it will fit.
But the link you provided says "out of stock". So it's possible that it's not available anymore.
Yes i know, i bought the last one hehe. So i hope it will fit.
My spare moped has a better spring i can use, I have tested them both and there
is an big difference between them.
The paint job went really bad, so i need to do the job for one more time.
But I am going offshore to work for 2 weeks now so I have to do it when getting home.
I have tried to open up my spare rear pulley tonight with no luck. I do not understand how
i can open it up. I have removed the nut i have described under here in picture. What do i do next?
I managed to get it off, there was allot of rust on the shaft. That was the reason it was stuck.
Hello Standreww.
I have not got the other one off yet. And i found out that the pulley on my spare bike
are EU version and the other one is US version. So i have ordered a puller tool to get the other one off.
http://www.ebay.com/itm/BGS-Tools-Rotor ... 58aafc5d9f
I am out offshore now working, so I am not able to do any more work before 2 weeks.
I will update on this forum when I have tested this and with a stiffer spring if it will fit.
For your information, the US pulley and EU pulley will both fit on my gearbox. I got this information
on a US forum. They are interchangeable.
For you guys that are interrested i found yellow and red spring for pulley.
Yellow is stiffer than stock, and was recomended for my setup.
https://www.treatland.tv/honda-contra-r ... yellow.htm
Red is stiffest and are recomended for more agressive setup.
https://www.treatland.tv/honda-contra-r ... ng-red.htm
Both are on the way to Norway.
Nice tip! Thanks for sharing!kalinkamaen wrote:For you guys that are interrested i found yellow and red spring for pulley.
Hehe nice. My goal is to have acceleration, so it looks like i am going the right direction then.
$43,50 to ship one spring to Belgium...kalinkamaen wrote:For you guys that are interrested i found yellow and red spring for pulley.
Hehe yeah its expensive. But i live in a expensive country, so for me it is not so bad.
If you guys want i can give the dimensions of both springs when i get them. And you
Can try to find something similar springs for other bikes?
