Honda Camino 65cc kit
kalinkamaen
Post by kalinkamaen »
Hello guys. I am new on this forum.
I have a camino p50 2 i think. And i have just upgraded to 70cc.
I will recieve a proma exhaust tomorrow.
I have started it as it is now, with stock exhaust and stock carb jet.
It runs but it will not idle. So i need to drill my orginal jet. What size
drill do i need to use?
I have ordered this kit:
http://www.ebay.com/itm/390688134113?ss ... 1497.l2649" onclick="window.open(this.href);return false;
Regards Morten
Re: Honda Camino 70cc kit
I don't think you have to drill the jet.
A stock jet is good for the setup you've got.
That the motor wont idle is probably because the carburetor is dirty.
Try out the folowing link
http://translate.google.com/translate?j ... l=nl&tl=en" onclick="window.open(this.href);return false;
kalinkamaen
No the carb is not dirty. That i am 100% sure about.
I have just cleaned it and it ran perfect with stock setup. Then there must be something else.
If a camino won't idle is because the carb is dirty beneath the silver screw.
Try to blow air of a aircompressor trough the hole beneath the silver screw on the carburetor.
If that doesn't help, do it again, and again.
kalinkamaen
Yes i know. I found the problem. i managed to put the piston wrong way, sorry i am
a total noob. I was luky the piston rings didnt snap. Its running good now, but i not 100% happy.
I will post you a video of the sound it makes. Its like metal banging.
kalinkamaen
Check tihis move for the sound. I will post a sound when running ASAP.
[youtube][/youtube]
Ok, not a carb problem.
Weird sound. Piston should be with ex to the bottom.
Or sometimes there' s an arrow on the piston, it should always be at bottom.
If there's a hole in the Piston, it should be upwards.
Maybe the sound is piston slap.
kalinkamaen
Here is the sound when running. Is it a normal sound? I could not see any
marks on the piston!
[youtube][/youtube]
kalinkamaen
standreww wrote:Ok, not a carb problem.
Yes you are right, arrow down against exhaust. And the hole upwards.
What is piston slap?
Than the piston hits the cilinderhead.
2 gaskets between cilinder and motor would prevent the pistonslap.
Or a 65cc cilininderhead.
kalinkamaen
standreww wrote:Than the piston hits the cilinderhead.
But as i described, i could NOT see any marks on piston.
Could be piston slap, put this is a cylinder kit. Came with cylinder, piston and rings togehter.
Is it bad driving like this?
Yes, it's bad driving like that.
Try 2 gaskets between motor and cilinder.
Yes everything must be made loose again.
The hole in the piston must be upwards, but i don't think that is the problem.
kalinkamaen
I have had everything off again and the piston is correct now.
But i still have the knoking sound. So i need to order a new gasket and put 2 on.
Is that what you are suggesting?
Regards Morten.
Yes that's it. 2 gaskets should do the trick.
Not the metal one.
But the one between motor and cilinder.
kalinkamaen
Oki thanks, i have ordered 3 kit now. So i have to wait and see :) hope it helps.
I understand what gasket you mean. But thanks for pointing it out though.
The camino runs pretty nice with 70 cc and rest stock. :) Looking forward to test it with
exhaust on. If i want to drill my carb jet. What size should i start with? 0,8 mm?
