Stock Honda Carbs
rarexro
Stock Honda Carbs
Post by rarexro »
Here in the US, only two types of carburetors were provided: a 10mm venturi; and a 12mm venturi.
I was just doing various google searches, and found a seller with what is claimed to be a stock Honda carb with a 16mm venturi.
What size carbs were available outside the US?
Santa Cruz
Re: Stock Honda Carbs
Post by Santa Cruz »
It's a 12mm venturi what's original for Camino ... But you can use bigger carburators (Keihin, Dell'Orto, Mikuni,...) such as 16mm, 17.5mm, 19mm, 21mm,...
rarexro
Post by rarexro »
Thanks!
I had suspected that the seller had measured the throat of the carb. It looked to be a stock carb to me.
