engine swap for honda camino
Hey guys so my engine had bad compression due to a bolt being snapped and looks like it had been snapped for a long time, anyway my machanic might not be able to remove the broken bit from the engine and at this rate i might need to fit a diffrent engine. only problem is a lot of engines are chain driven or run off the back wheel so i was wondering what options do i have this is a last resort for me as i love the bike i don't wanna sell it i just wanna change the engine if possible or does anyone on here have a spare 49cc engine
Re: engine swap for honda camino
you can simply change the crankcase,
when you do this you can also overhaul the engine
new bearings
new gaskets
this will help you
http://www.camino-tuning.be/handleiding ... 11715.html" onclick="window.open(this.href);return false;
when you put an add in the "wanted" topic
someone will sell you parts and send them to UK
good luck
new bearings
new gaskets
this will help you
good luck
I can deliver you a complete rebuild engine if you wish.New crank,new bearings,new casket and new oil seals.Also the complete body sandblasted,looks as new than.Let me now if you interested.Is your engine a vario or mono?
hey Den i just messaged you, how you mean is a vario or a mono ?
here is the engine dan
That's a vario, look at your sidecover at the back, it says "Variomatic" and it means it's a constant variable trasmission. There also another type which is fixed and only has on gear.
The guy your talking to 's name is Ives, "den" just means "the" Ives in Dutch
ohh haha sorry i didn't know it was dutch, i can't look at my engine at the moment the machanic has got it trying to get the bolt out but im just waiting for a reply back off Ives
