Camino/hobbit stops accelerating for a little moment
GillesCl
Post by GillesCl »
Hello
My camino/hobbit accelerates pretty quick to about 40km/h, but then it stops for like 2-4 seconds and slows down to about 30km/h and then goes back again up to around 60km/h. I don't know why this is happening hope somebody could help me here.
Re: Camino/hobbit stops accelerating for a little moment
Hello Gilles,
Is it like this every time, or only when the engine is still cold?
hello gillles
how is the sound as it slows down ?
is it like it is prrrrrrrrr
and than it goes back a little faster ?
can be the max limit of the org cilinder of exhaulst
grtz m ;)
GillesCl
Post by GillesCl »
It's like always even if i've ridden for half an hour
GillesCl
Post by GillesCl »
It sounds and feels like it loses all power for that moment and then gets back at it
hello
test is if he drives better with choke at front
if so carbu clean maybe nessasary
the moped has it a longtime not being running ?
does he stays stationair turning?
and if it makes the sound prrrrr ? and than goes back faster ?
it's a limit that honda maked in the org honda cilinder and org honda exhaulsts
of maybe check also the gate of the cilinder ,maybe he is full with 2 stroke oil , and the hole is little
you can clean it
of the exhaulst is ful with oil
set the bolts off the exhaulst a bit looser under the cilindr
if it goes faster
your exhaulst si maybe needed for a new one
but check
also if he runs better with the choke always on
if so
clean the carbu
good luck
grtz m ;)
GillesCl
Post by GillesCl »
Hey,
I don't think it's gonna be the exhaust because its a brand new proma exhaust but ill check the choke and the other stuff
Thanks!
ok
check that ,
and let us know
grtz happy 2017 ;)
