Hello I thought I'd join as I can't find the info I'm looking for and hoping you guys can help. I've acquired a Camino sport like the dx model with the round headlight in a rather sorry state that's been off the road the years.
Loads of bits was missing like headlight rear light ect. I've now got most parts needed but I'm not sure if my model comes with a resistor that bolts to the horn bracket for the low beam. There's a white wire that's not plugged in to anything so I'm thinking I'm missing the resistor for this. I thought models with brake lights was fitted with a resistor looking at some wiring diagrams. Mine does not have a brake light.
Any help appreciated.
http://i223.photobucket.com/albums/dd26 ... ltaet.jpeg
http://i223.photobucket.com/albums/dd26 ... q6vwp.jpeg
Headlight resistor
Re: Headlight resistor
this is the resistor for that light
the little light and the big light
and the second resitors is for the stoplicht behind
thats why it's a doubble one
but if you don't have a brake light
than i suppose is one like on this second photo enough
for the uk camino's
Hello, Ok I thought I was missing a resistor. Could I use a modern 30 ohm 5 watt resistor like this built in? http://uk.farnell.com/multicomp/mcprw05 ... 0000081233
I just found this which is also a uk wiring diagram and looks the same as mine. http://i223.photobucket.com/albums/dd26 ... eitjm.jpeg
tgo
maybe it could
but nothing to find in the uk on e bay ?
but you can try it out
but the resistor
my opinion
if you have no brake light
the light works on a 6 v alternator
it works perfect without also
and the little licht in the headlight is not like a wallaroo of other 12 volt moped , of scooter , that's shines so far
try if it works without
maybe it could
but the resistor
my opinion
I've not really been looking for a oem Honda part as I wasn't sure if it was needed so I'll keep that in mind and might try a cheap resistor if it's needed.
It did blow a rear 6v 4w bulb when I first wired the rear light up but that was more likely a faulty bulb so replaced with a 8w bulb and seems ok for now.
Front bulb was rather warm after a few minutes too but it didn't blow. If it keeps blowing bulbs do you think I'll need a resistor wired in as shown in my wiring diagram? The resistor is only linked to the white headlight wire unlike the models fitted with brake lights.
Thank you
Thank you
hello
the 6v 4 watt bulbs das a little mistake of honda
there are very weak
all of the time they are going broken
now if i myself lay a cable i use at front 6 v 15 watt off 6 v21 of 6v 20 watt bulbs
and with no stoplight a bulb behind 6 v 10 watt
thats for sure a better combination
don't use 12 a 6 v bulbs together
that is also for problems
i mean 12 v at front and 6 v behind is not good , the rear light will go always be broken
its important
the voltage
camino org alternators are 6v to produce
at one cable of the alternator
the red one
it produce the light for front and behind together
dont use a rose and red for each light
and the massa on the farme the blue one
but i propose try a 6 v 10 watt behind in combination with a 6 v 15 of 20 watt at front
noramly it works perfect
and with no resistor needed
the resitor for that model of frontlight is normaly for a 2 way bulb
a little light and a bigger light
but the bigger one produces just enough light for a good frontlight
the little one is lika a a candle light ,you don'tsee much with it
i wish you good luck
keep us informed the way it goes
thank you for consider the site
grtz m
there are very weak
its important
the voltage
the red one
grtz m
Hello
I didn't know Honda listed the wrong rated bulb for the rear! So that'll explains why it blew straight away.
I'm a little confused as to what front bulb your telling me to use? A 6v 15w or a 6v 20w bulb? I have a 15w and a 18w one I could try. I'll also get myself a rear 6v 10w bulb and try this combination.
I know not to mix 6/12v bulbs
The alternator wiring I have is, black/white going to coil, pink green and red as shown below
http://i223.photobucket.com/albums/dd26 ... oovtb.jpeg
My red wire don't have a matching color plug for the main loom so it's left unplugged. Blue is the main earth, pink or the green is the power for the lights/horn I think.
I think my headlight is a 2 way bulb as there is 2 filaments in the bulb, low/high beam controlled by the main switch. I should also state there's also a little pilot light for the high beam light that lights up blue. I think I installed a 1.5w bulb.
I will keep you informed and get some better pictures
Thank you for the advice
