I am restoring a Honda PX-R, but I can’t get it to work properly.
I have put on a new cilinder and piston, new CDI unit (that caused it to start), I cleaned the carb, cleared all rust from the gas tank and put new rollers in, but it still only goes 10km/h max.
What else could be the problem? I do note that there is a lot of noise coming from where the v string, rollers and clutch are (idk the English word that that section haha). Any suggestions are welcome!
PX-R new cilinder, clean carb and gas tank, new rollers, new CDI, still slow.
Re: PX-R new cilinder, clean carb and gas tank, new rollers, new CDI, still slow.
hello
you changed the variorollers ?
measure please ?
wheigt of them ?
what for ramp vario plate do you got flat or bowed ?
i think px has 13x16 like honda wallaroo
you can change also the varioplate
for px B kl 40 ph
rear to find
but the wallaroo stars white a little adaption can also be fitted S72 star is most bowen , i think org for older model honda vision
i think stil to buy
good luck and succes
best regards
measure please ?
wheigt of them ?
for px B kl 40 ph
rear to find
i think stil to buy
best regards
