PX50 'A' restrictions.
Greetings from the UK!
I have a 1985 PX 50 from Belgium. It is a class A type, so limited to 25kph. Can you tell me what is done to restrict it to this speed?
Thanks!
Thanks!
Re: PX50 'A' restrictions.
hello
you can change the variopres star at front
you can use on from a honda wallaroo , just amke it hole ti fit on px
and make the exhaulsy hole of the cilinder a litter bigger
of place as example a 65 cc cilinder dr of polini
but the star you need to change to get lower rpms , others you heat the engine so high , that the cilinder goes broken by overheating
good luck
questions just ask
best regards from belgium
good luck
questions just ask
at foto thats px kl b 40 p h star
this is the fast arrow star from wallaroo ,
as you make the mid hole as px it fits perfect
so can your belt at front getting higher and rear lower so that the vario realy works
the 25 p hous are just for the law and the vario's don't work as they have to do
from wallaroo i got stil a few
good luck
best regards
good luck
best regards
Hi,
Thanks for getting back to me so quickly!
I want to keep the bike looking standard, as it's in really good original condition. But I would like a bit more power.
Would fitting a 65cc kit with a wallaroo vario, with everything else as standard be a worthwhile upgrade?
Also, if you have a spare Wallaroo star, I would be interested in buying it, as not much is available over here.
Thanks.
Thanks.
you have to see that its a bowen one as on the foto
the flat ones have no use
tha vario will not work
good luck
best regards
good luck
best regards
Do you have any of the parts I need for sale?
I can't find much over here.
Thanks.
Thanks.
i got the wallaroo star ,
that you can make fit
best regards
ps
got also occasion fast 50 cc cilinders with new pistonkit
best regards
ps
Thanks. I have PM'ed you.
Hi,how are you,im also in the same situation,im in ireland and have 2 belgian px50,do you have 2 wallaroo stars you could sell? Thankscamino_expert wrote: ↑26 Apr 2020, 23:45 this is the fast arrow star from wallaroo ,
good luck
best regards
hello , i stil got wallaroo stars org honda stars
those are 20 euro a piece
i wil look tomorow if i got stil the cheaper ones
thank you
best regards
thank you
best regards
