PX50 'A' restrictions.
260ppc
Post by 260ppc »
Greetings from the UK!
I have a 1985 PX 50 from Belgium. It is a class A type, so limited to 25kph. Can you tell me what is done to restrict it to this speed?
Thanks!
Re: PX50 'A' restrictions.
hello
you can change the variopres star at front
you can use on from a honda wallaroo , just amke it hole ti fit on px
and make the exhaulsy hole of the cilinder a litter bigger
of place as example a 65 cc cilinder dr of polini
but the star you need to change to get lower rpms , others you heat the engine so high , that the cilinder goes broken by overheating
good luck
questions just ask
best regards from belgium
at foto thats px kl b 40 p h star
this is the fast arrow star from wallaroo ,
as you make the mid hole as px it fits perfect
so can your belt at front getting higher and rear lower so that the vario realy works
the 25 p hous are just for the law and the vario's don't work as they have to do
from wallaroo i got stil a few
good luck
best regards
260ppc
Post by 260ppc »
Hi,
Thanks for getting back to me so quickly!
I want to keep the bike looking standard, as it's in really good original condition. But I would like a bit more power.
Would fitting a 65cc kit with a wallaroo vario, with everything else as standard be a worthwhile upgrade?
260ppc
Post by 260ppc »
Also, if you have a spare Wallaroo star, I would be interested in buying it, as not much is available over here.
Thanks.
you have to see that its a bowen one as on the foto
the flat ones have no use
tha vario will not work
good luck
best regards
260ppc
Post by 260ppc »
Do you have any of the parts I need for sale?
I can't find much over here.
Thanks.
i got the wallaroo star ,
that you can make fit
best regards
ps
got also occasion fast 50 cc cilinders with new pistonkit
260ppc
Post by 260ppc »
Thanks. I have PM'ed you.
ok
thanks ;)
Seanpx50
Post by Seanpx50 »
camino_expert wrote: 26 Apr 2020, 23:45 this is the fast arrow star from wallaroo ,
good luck
best regards
Hi,how are you,im also in the same situation,im in ireland and have 2 belgian px50,do you have 2 wallaroo stars you could sell? Thanks
hello , i stil got wallaroo stars org honda stars
those are 20 euro a piece
i wil look tomorow if i got stil the cheaper ones
thank you
best regards
